Posted: Sun Mar 08, 2009 8:59 pm Post subject: Brake fluid from ??? |
Hey boys and girls, I've got a good question for you. Here is the deal. The 67 bug I maintain is losing brake fluid, but from where? The brakes work very well and don't fade and the pedal does not go down if it is held with pressure. There is fluid dripping from the hole in the pan in the rear just in front of the transaxle, so it is coming down the inside of the tunnel. To me that would indicate the master cylinder, but it seems to be fine. I've checked all around the pedal cluster and can find nothing. Any ideas???  _________________ 73 Typ481
Posted: Sun Mar 08, 2009 10:05 pm Post subject: |
Could a pin hole have been rubbed in the hard line that runs the tunnel or a rust hole? _________________ 71 Standard Beetle "Big Bird"
Posted: Sun Mar 08, 2009 10:45 pm Post subject: |
No brake lines run down the tunnel. The line runs down the inside of the car. No apparent leaks there. _________________ 73 Typ481
Posted: Mon Mar 09, 2009 7:09 am Post subject: |
Lake Jims was doing the same thing. It was the master cylinder. It was leaking wher it comes through the fire wall and running down the tunnel. _________________ 73 Super
Posted: Mon Mar 09, 2009 8:35 am Post subject: |
Joe wrote: | Lake Jims was doing the same thing. It was the master cylinder. It was leaking wher it comes through the fire wall and running down the tunnel. |
That's what I was afraid the answer would be.
Hey Clyde, got a master cylinder for a 67 Bug? _________________ 73 Typ481
Gary
Posted: Mon Mar 09, 2009 9:49 am Post subject: |
Hello out there !! - Jon I second
the master cylinder Pearl is also doing
that. I need to replace it
Thanks Gary |
Posted: Mon Mar 09, 2009 9:54 am Post subject: |
Thanks for the help. Clyde has master cylinders, so I'll be swinging by his house tonight to pick one up.
Good to see you are alive Gary.  _________________ 73 Typ481
