Posted: Tue Oct 28, 2008 8:02 pm Post subject: I need a fat guy |
To help me get the stupid nut off the rear drum!
Crap that thing is tight I jumped up and down on it for 30 minutes and it didnt budge. Any tips on removing it? I need to replace the wheel cylinder before I drive anymore. |
Posted: Tue Oct 28, 2008 8:05 pm Post subject: |
You need an impact. To loosen it and tighten it. If you don't get it tight enough it will strip the splines and it won't go. _________________ Shane Price
Posted: Tue Oct 28, 2008 8:51 pm Post subject: |
just my 2 cents-it is good to use an impact to take off but a torque wrench should be used to put on-and torque to proper specs--home depot has a cheaper impact but i would get one from sears -a craftsmen is good and pretty strong- ok that was 3 cents lol-maybe it is different for vw-dont know that is just what i was tought and practiced at hayes dodge when i worked their ! _________________ flat black 68 with biggies on back skinny up front- no power and i dont need wax!!!always ready for icecream !!! |
Posted: Tue Oct 28, 2008 10:00 pm Post subject: |
You worked at Hayes? . . I work at an independent shop in Conyers and we get parts from Hayes. Anyway.Thats what all techs are tought in the begining. But no one does that . At least no techs that I know. I have hammered on thousands of axle nuts of all manufacturers and had zero problems . Besides it torques to over 200 ft lbs. You wont use that torque wrench very much. I run it down and give it 2-3 good bursts and put the pin in it. It will be fine. Don't get me wrong Scott, I understand being carefull. But from my experience you will have more problems from under torque then over. _________________ Shane Price
Posted: Tue Oct 28, 2008 10:17 pm Post subject: |
I've got the torquemiester tool that makes easy work of removing and re-torqueing the axle nuts. You are welcome to borrow it. (if and when I get it back.....hello...Mark? ) _________________ 73 Typ481
Posted: Tue Oct 28, 2008 10:55 pm Post subject: |
This and a 3lb sledge hammer. Never had a problem.
Posted: Wed Oct 29, 2008 8:04 am Post subject: |
OK so I need a fat guy with an impact wrench.
Thanks guys I will try the impact tonight. Also what is the exact size off the castle nut? I was using a 1 1/2 but I think it should be a 36mm? |
Posted: Wed Oct 29, 2008 10:10 am Post subject: |
Adams77 wrote: | OK so I need a fat guy with an impact wrench.
Thanks guys I will try the impact tonight. Also what is the exact size off the castle nut? I was using a 1 1/2 but I think it should be a 36mm? | 36mm _________________ 71 Standard Beetle "Big Bird"
DiggerD
Posted: Wed Oct 29, 2008 1:45 pm Post subject: |
Give me a call, I think I PM'ed you my #. I have a 700 lb torque wrench that makes those stubborn axle nuts fall right off!! lol. Also you can make sure they are torqued to spec when you put em back on!
D. |
Posted: Wed Oct 29, 2008 5:14 pm Post subject: |
what shop do you work for-i no longer work at hayes i am back selling harleys, well trying to sell harleys.... i would like to get back into auto when people start hiring again!!! _________________ flat black 68 with biggies on back skinny up front- no power and i dont need wax!!!always ready for icecream !!! |
Posted: Thu Oct 30, 2008 7:13 am Post subject: |
I work for h&h auto on old covington hwy. Yeh, It sucks right now for mechanics. I'm doin side work alot more these days. _________________ Shane Price
Posted: Thu Oct 30, 2008 8:07 pm Post subject: |
Whew!
36mm socket and a 4 foot cheater bar.
Got it now. |
