Crank
Posted: Tue Jul 15, 2008 10:07 pm Post subject: Cams and Cam Gears |
Are there any split dur. cams that would be good for a 1776? I have a W110 just wanted to know if there is anything better. I want good midrang power . What abought straight cut gears for the street? I like the wine |
Posted: Wed Jul 16, 2008 8:12 pm Post subject: |
http://www.webcamshafts.com/
Click product search, and look at Volkswagen T1. I've got the 111 grind cam. Steve's got the 110 grind.
There are a few split duration grinds listed, but I don't know anything about them  _________________ '69 Bug, 1776, dual kadrons, Web 111 cam
Posted: Wed Jul 16, 2008 8:56 pm Post subject: |
And a 1776 really likes the 218 as well.. _________________ Jake Raby
Crank
Posted: Sun Jul 27, 2008 6:27 pm Post subject: |
Thanks I am going the 110 cam. Clyde My cam bearings want work the thurst is to wide. So I will see u Monday. |
Posted: Mon Jul 28, 2008 6:40 am Post subject: |
Lay a peice of fine sandpaper on a peice of glass. Then rub the thrust bearing on it in a figure 8. Use wd 40 as lube. Mic it or fit it on the cam. Repeat til you have the clearance neccessary (I think its .003 but double check the book). My rebuild book is buried presently . _________________ '69 Bug, 1776, dual kadrons, Web 111 cam
