Posted: Mon Oct 15, 2007 1:37 pm Post subject: carburators |
ok, whoever is the carburator guroo tell me what my meter should be reading when setting up dual webers. they all match but should the numbers be high or low? some info on this would be helpful . Thanks |
Posted: Wed Oct 24, 2007 4:49 pm Post subject: |
I beleive they should all simply match, but there may be more to it. I mainly deal with Kadrons, which don't need the snail tuner. _________________ '69 Bug, 1776, dual kadrons, Web 111 cam
Posted: Fri Oct 26, 2007 8:30 am Post subject: carbs |
hey thanks clyde for the info. It seems to run good just a little popping through the carbs when you rev it up. |
Posted: Wed Nov 07, 2007 9:48 pm Post subject: |
Sounds lean.. Popping under acceleration= lean..
It could be the accelerator pump output, idle circuit or main circuit..
Or it has too lazy of an advance curve, I bet it has a 009 dizzy, huh?? _________________ Jake Raby
Posted: Thu Nov 08, 2007 2:00 pm Post subject: carbs |
why yes, yes it does. Think of putting the electronic ignition in it. I am not gonna keep this car very long. When I build my dream engine, i will put msd on it. |
Posted: Fri Nov 09, 2007 7:00 pm Post subject: |
Here's a website that addresses your carb/disb issue.
http://www.aircooledtech.com/34pict3_modification/ _________________ Ya can't have too many VDUBS.
Posted: Sat Nov 10, 2007 3:18 pm Post subject: carbs |
thanks bob, looks a pretty nice site for the stock carb. I am not sure if I can transfer any of that info over to dual webers but will take a look and see. thanks |
