Posted: Sun Jun 09, 2013 5:40 pm Post subject: timing on the bus.... |
I'd like for someone to checkmy work, so I set the timing on the bus at 28 degrees BTDC with both hoses off and plugged. When I plugged hoses back in, I had a total advance of 35 degrees and an idle of 12 degrees ATDC.
The thing that concerns me is that I had to open up the air bypass valve on the throttle body to get it to idle (around 800rpm) Any and all thoughts welcome  _________________ 1969 Beetle
Posted: Sun Jun 09, 2013 7:06 pm Post subject: |
With vacuum you will have this 35-36* of timing, but not under load. _________________ Jake Raby
Posted: Sun Jun 09, 2013 7:26 pm Post subject: |
Mountain Power House wrote: | With vacuum you will have this 35-36* of timing, but not under load. |
Good to know  _________________ 1969 Beetle
