mackay
Joined: 19 Oct 2011 Posts: 73 Location: North High Shoals, GA
Posted: Sun Feb 17, 2013 1:19 pm Post subject: CHT gauge for my 74 Westy |
Any opinions on Dakota Digital's 2 1/16" Odyssey / Solarix? JM |
Posted: Sun Feb 17, 2013 6:34 pm Post subject: |
They work fine. Install the sender under the #3spark plug and you'll learn a lot on your first drive. _________________ Jake Raby
mackay
Posted: Sun Feb 17, 2013 7:15 pm Post subject: |
Thank you Jake. JM |
mackay
Posted: Sun Feb 17, 2013 9:45 pm Post subject: |
Well you sure made it easy on me, I'll order it tonight. Thank you Greg. JM |
mackay
Posted: Fri Mar 15, 2013 10:26 am Post subject: |
Hello all, Now that my CHT gauge is installed, what numbers should I look for? JM |
Posted: Fri Mar 15, 2013 11:06 am Post subject: |
What kind of readings do you get now in normal flat driving? _________________ 1969 Beetle
mackay
Posted: Fri Mar 15, 2013 8:47 pm Post subject: |
I haven't driven it much yet, but it seems to run in the mid 300s. JM |
Posted: Fri Mar 15, 2013 11:20 pm Post subject: |
If the sender is under the #3 plug you should see the following:
Light load, flat driving-280-330
Heavier load, up slight grades- 340-375
Larger hills, mountains or in a head wind in the middle of summer- 375-400
Anything more than 400 is critical and is an indication of mistuning or a less than optimum engine combination.
If you can keep the heads 325-350 all the time the engine will last forever. I dod this with my 912E and it went 160K and had no signs of being tired when I pulled it down to update it. _________________ Jake Raby
mackay
Posted: Sat Mar 16, 2013 8:37 am Post subject: |
Thank you Jake! JM |
mackay
Posted: Fri Mar 22, 2013 6:24 pm Post subject: |
Jake and all, I seem to be running around 380 or 390, any idea how I can bring that down? JM |
Posted: Fri Mar 22, 2013 9:40 pm Post subject: |
Is that up hill or on flat ground?You need to drop 30-40 degrees if those numbers are on flat ground in this type of ambient temp we've been having. Is the gauge you have a VDO? _________________ Jake Raby
Posted: Fri Mar 22, 2013 10:32 pm Post subject: |
I believe he got a Dakota Digital gauge. _________________ 73 Typ481
mackay
Posted: Fri Mar 22, 2013 10:38 pm Post subject: |
It is the Dakota Digital, that's mostly flat ground. It varies, of course, with the high begin only a couple of points above 400 for just just a few seconds. JM |
mackay
Posted: Fri Mar 22, 2013 10:46 pm Post subject: |
That should have said being, not begin. JM |
