Posted: Mon Jul 02, 2012 8:00 pm Post subject: part numbers from dakota digital |
I contacted dakota digital about a couple of gauges (cht, oil temp, and a pressure switch). I figured I'd pass the info along since it may be useful to the other bus folks. The cht and oil temp are temperature compensated. Since I'm bad with math, this is my choice They don't do the cool looking analog gauges but you'll get an accuate readout. (time to start a gauge fund)
SLX-11-1 CHT
SEN-11-8 18” length with a 14mm ring terminal for your application
SLX-07-3 Oil Temp
SEN-04-3 Temp sender
SLX-03-1 Oil Pressure
SEN-03-1 Pressure sender _________________ 1969 Beetle
