Posted: Mon Sep 26, 2011 10:45 pm Post subject: Turn signal stops |
This problem just started last week; everything work correctly previously. Now the right turn signal works fine until I step on the brakes. Once I step on the brakes, the signal blinks twice more and then it stops. If I re-engage the signal, it blinks twice and stops. The left signal works correctly. My best guess is a ground problem.
Any other thoughts? _________________ 73 Typ481
Posted: Wed Sep 28, 2011 8:01 pm Post subject: |
Check the grounding of the housing on your front and/or rear fender on the errant side. If it's only one side, it probably ain't the switch. maybe? _________________ '69 Bug, 1776, dual kadrons, Web 111 cam
