iggy
1972 Volkswagen Beetle
Posted: Sat Jul 10, 2010 1:09 pm Post subject: Wiring for a 34 pict carb |
I am trying to get my bug on the road and I am having trouble getting the carb tuned so it will stay running. I can get it started and it will run beautifully but then just cut off. In my investigation I discovered that the automatic choke is getting really hot. I am wondering if the cut off and choke could be wired wrong. They are both wired directly off of the positive side of the coil, is this correct?
Thanks! I know I am new around here so as soon as I can I will post an introduction as soon as I can. |
cavediver520
Posted: Sat Jul 10, 2010 1:23 pm Post subject: |
Yes, that is corect, they both should get power from the + side of the coil...hope this helps out. |
iggy
Posted: Sat Jul 10, 2010 1:24 pm Post subject: |
Thanks, Is it normal for the automatic choke & cutoff to get really hot? |
Posted: Sat Jul 10, 2010 7:44 pm Post subject: |
Are they connected to the same terminal on the coil as the wire coming from the ignition switch?
I've seen quite a few cars lately with the coil mounted backwards, and it messes with my brain.
If it's connected to the side with the condenser, I could see it causing problems.
The choke works by heat, so it ought to be cold at start up, and warm up as the car warms up.
Does the shut off valve click when the key is turned on? _________________ '69 Bug, 1776, dual kadrons, Web 111 cam
Posted: Sat Jul 10, 2010 8:27 pm Post subject: |
sorry about the coil thing clyde I'll try to swap it 'round right when I can  _________________ 1969 Beetle
Posted: Sat Jul 10, 2010 9:48 pm Post subject: |
No big deal, Greg. Jeff's was the same way. The main thing is that you remember that when messing with the wiring, so you don't fry the electronic module. _________________ '69 Bug, 1776, dual kadrons, Web 111 cam
iggy
Posted: Sat Jul 10, 2010 10:52 pm Post subject: |
Clyde wrote: | Are they connected to the same terminal on the coil as the wire coming from the ignition switch?
Does the shut off valve click when the key is turned on? |
The Shutoff & Choke are on the same terminal but it is a different terminal and they are on their own terminal.
And Yes the cut off clicks when I hook it up.
I will see if I can get a pic of my setup posted tomorrow. |
iggy
Posted: Wed Jul 14, 2010 8:55 am Post subject: |
I discovered the problem I was having was caused by a sticking needle valve. I now have the bug on the road! I will try to get some pics together soon. |
Posted: Thu Jul 15, 2010 7:19 pm Post subject: |
Clyde wrote: | No big deal, Greg. Jeff's was the same way. The main thing is that you remember that when messing with the wiring, so you don't fry the electronic module. |
Sorry on mine too !
I also will swap it asap!
Dont want to mess with the brain !
Thanks for the help
Jeff Epperson _________________ Jeff Epperson
Blowin Smoke BBQ |
